Pr2019: How to "actually" split clips
As part of learning by doing, I'm building a fan-music-video to get my chops back, after not touching Pr since Pro2.
As you might imagine, this entails cutting lots of little clips out of long source footage.
What I *expect* to be able to do is mark clips somehow in the long source clip, and then cut them out, *into separate clips in the bin, named, and not interacting with one another*. The Metalogging workspace, which I understand to be intended for initial footage logging and handling, has no timeline, and it appears that "put the clip on a timeline", is the only way to do this sort of splitting.
But I forsee two problems, and I'm not sure what to do about either of them:
1) What timeline/sequence should I use for doing this splitting, and if the source footage is of a different standard than the project/final program, how will those two interact -- I'd prefer not to have to render that early... and also where do I *get* that timeline? Do I clutter up the Program timeline, and then clean it up after? Or create a new sequence and then discard it (a Timeline is the viewfor the model that is a Sequence, right?)
2) It appears to me, so far, to be the case that {WARNING: theoretical example ahead} if I import a single 10 minute clip into a program and bin, called SAMPLE.MPG, and put it on a timeline and razor it into 3 3.3 minute clips, all three will still be called SAMPLE.MPG, and there will still only be one clip in the bin. If that's true -- and especially if I can't rename the three clips independently -- that's going to drive me up a wall. Is that in fact the case, and if so, how does one get from where that leaves me to where I want to be?
Do I really have to do that, and then manually export each clip and pull it back into the bin?
Or is there magic I'm simply not seeing for this circumstance, which really can't be *that* uncommon, 3 decades into nonlinear editing... 🙂
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from generic Cloud/Setup forum to the specific Program forum... Mod]
