Premier Pro 15.4 and 15.0 Crashing and not opening on Mac Pro 2013 Big Sur
  • October 11, 2021
  • 238 views
Hello I updated Premiere Pro to 15.4 version and I couldn't open it, it crashes right away. I tried the 15.0 version. It crashes also.
Hum, problem... I can't work now...
Any help please ?
Adobe Employee
October 16, 2021
Hi there,
Sorry to hear about this. Are you still experiencing this issue? If so, please share the system specs (OS, CPU, GPU & RAM) Also, let us know if any crash log is generated on the system. It will help us to diagnose the issue properly.
Sumeet
Hi Sumeet,
Yes it is still crashing at launch.
System specs
Mac pro (2013) 
MAC OS BIG SUR 11.6
3,5GHz intel Xeon E5 6 coeurs
63 Go 1866MHz DDR3
AMD FirePro D500 3 Go
It is just saying it had to quit for unexpected reason... cf. screenshot
Thank you for your help,
Mike
After Effects latest version works fine.
But not Premiere Pro and not Media Encoder.
This is the TERMINAL MESSAGE, when i try to use Media Encoder with After Effects.
Is it helping ?
Any solution ?
Thx,
Mike
