Premier Pro keeps crashing when exporting (similar issue reported by others and not resolved)
Hey! So I'm experiencing the same issue as several others have been reporting, and from my viewpoint there seems to have been no real fix to this.
When exporting my project crashes, doesn't help to use media encoder, nor clearing cash or any of the suggested solutions. This has now affected all my projects and I'm unable to export anything.
I've tried different projects that previously worked, re-importing, re-installing, etc..
This does seem to be a problem tied to the H.264 codec.
I'm using a M1 Macbook Pro (12 gb ram)
Somona 14.7.4
Håkan282156173ngkCorrect answer
IT WORKS!!!!! New update fixed it *chefs kiss*
Doesn't help disabling hardware acceleration unfortunately.
I'm using the latest version of Premier Pro, I've also tried downgrading to a previous version.
I am able to export in other codec, but all exports tied to the H.264 codec crashes.
Adobe Employee
February 27, 2025
Hi Håkan282156173ngk,
Sorry to hear about this. We will get it checked. Could you please confirm the version of Premiere Pro that you are using? For testing purposes, please try disabling hardware accelerated decoding under Premiere Pro > Settings > Media & check if it's exporting properly.
Sumeet
