Premier Pro not working after update.
  • May 11, 2022
  • 1891 views
Hi Folks,
Half way through an edditing job yesterday, Pr started acting up. Every click was taking 2 seconds to register (there were no other processes grabbing at the CPU), Clicking "Play" does nothing, Clicking "Go to in" stopped responding, and clicking anywhere in the timeline is being ignored. I cant highlight tracks. Some windows respond to mouse click, but all the core stuff is screwed.
I updated Pr and I've got the same today. PR is all over the place. Upon opening, my windows are all popped and I'm having to put them all back manually becasue the Workspaces arent working as a default. All of the other issues I menioned above, are still here despite the refresh.
Any ideas anybody?
P.S. all other apps on the PC are working fine. No virus' detected and no reason to think the issue lies outside PR. Running an Alien i7 with a GeForce 1080 & 32Gb.
Thanks Folks,
D
marcebinger
This is happening to me as well...very frustrating.  I have a high end Alienware laptop and all was working great until this last update.  All drivers are updated, I did a reinstall and restart...nothing helps.
Marc
reinstall the previous version that was working.  it is available in the creative cloud app
There are all sorts of things that can cause these sorts of issues outside of premiere.  Make sure you have plenty of free space on your startup and media drives, a minimum of 10% on all drives and 20% on your startup drive and run a drive speed tool to make sure your drives are not failing.    As a troublehsooting step, try restarting your computer and make sure no other apps are running.   Try disconnecting your computer from the internet/network by turning off wifi and/or pulling the ethernet cable.  try creating a new user account on the computer with administrative privileges and signing in to that account...  I think there are a few good posts here on troubleshooting steps on windows.  probably a good idea to search this forum.
DirjampaAuthor
Hi there, thanks for the advice, but thats all covered. This is a squeaky clean editing PC.
I'll keep hunting. Cheers.
D
hardware can fail.  and every drive will fail and sometimes can fail right out of the box...   certainly worth a few minutes to check the drive read/write speed...     bwdik.  good luck and let us know if you figure out the issue(s).
FAQ: How to reset (trash) preferences.
If not:
deinstall, use cleaner tool and install again.
DirjampaAuthor
Thanks.
