jbreeckner
Premier Pro - white dots appearing on eyes
  • July 22, 2020
  • 7 replies
  • 1596 views
Hi, I was wondering if someone could give me a work around with an issue I'm coming across in Premier Pro with some  geen screen video I shot.
The issue I'm having is when I change the background to pure white/light gray, there are white dots that appear and disappear on the subjects eyes. When the background is pure black, I don't have this issue. I've tried an elipse mask and inverting it, but the subject moves her head around too much so the mask isn't very effective.
Below is a screenshot of what I'm seeing. Is there a way to fix this without using a mask? Any suggestion are greatly appreciated!
good going Warren. In your opinion are the white dots in eyes spectral highlight from lighting when she moves her head and eyes into the light ?? ( same with lower lip ) ??
THIS is sample of a spectral  highlight in the eyes of a model. The light source is reflected in the eye.
Is fairly common.
I think it's spectral highlights from lights, and the key just wasn't clean
hehe, poster just wants to avoid using mask or doing anything to fix it... so all this response is kinda moot.
maybe we could suggest how to turn the white dots in eyes into red dots, and then expand the feather and brightness of red slightly over a few frames, and this red evil light from a horror movie character ( our poster's sample pic ) shoots out of her eyes and lip !!!!!!!
SCARY !
not that it matters, but in resolve 15 there's a mask setting for looking at the product of the mask, namely a black and white 'result' of opacity, so you can actually adjust the thing or do what has to be done later in another node or mask.  Hard to explain, but it's not a suprise.... it's easy to see in program monitor.
I don't know if your version of ppro has that sort of ability, but you shouldn't have to wait for the export to see the results.
sounds like you have holes ( transparancy) in the green screen so that would be adjusting the parameters of the screen attributes ( frame by frame so you see those instants where the eyes are moving through lights ( spectral highlights )).
You're right, it's a question of the 'mask' adjustments to fix that.
I doubt PPro has the ability to do that sort of adjustment but AE might.
jbreeckner
That makes sense. So I can adjust the transparency frame by frame? Everytime I try, it seems to adjust it for the whole sequence. I'm still VERY new to Premier Pro (been relying on Youtube tutorials to get as far as I have with it lol) and AE is also something I've never messed with either. I'm hoping to figure out a fix that someone can explain to me easily that doesn't include a mask.
I'm with PeruBob ... I would expect it has to do with the color of her eyes, and the easy fix is simply to track an oval mask on most of her face. Won't affect the rest of the image, but would 'protect' the eyes from the green-screen matte.
See white dots on lips; green lipstick? 😉
Peru Bob
Does the subject have green eyes?
jbreeckner
Nope! She has brown eyes
Difficult to see as the screenshot is rather small.
Please post a image of the original footage with the green background.
Also post computer specs, OS and Premiere build and media used.
Guessing you key is too agressieve.
pure white is filling the holes created by the key.
jbreeckner
Here's a screenshot from the original footage, let me know if you can see it okay. I understand my green screen background has ripples and shadows, the lighting I had to work with wasn't the best either. Overall this was a difficult shoot and it's made it rough to key in Premier.
Dell Laptop (not sure the exact model, it's my work computer) Windows 10
Premier Pro 2020
Footage shot on a GoPro Hero 7 Black in 2.7K at 30fps
Warren Heaton
I managed to get a better key than I expected from Keylight in After Effects.
My best guess is that you're getting occasional macro blocking as a result of keying a highly compressed inter-frame 420 color-sampled file format.
