ondrej.sevcik
Premiere and Element 3D problem
  • May 2, 2023
  • 609 views
Hello, I have a project in Premiere including few clips from After Effects where Element 3D is used. When I export directly from timeline all is good but when I send it to Media Encoder then all clips with Element 3D are not rendered. Since that is a series what I am working on I prefer to render all parts from Media Encoder queue instead of manually render each part from Premiere. I tried to render that clip with Element 3D from AE via Encoder and it worked, just Premiere screws it up through Encoder. What can I do to fix that? Thx a lot
MacBook Pro
2.6 GHz 6-Core Intel Core i7
Radeon Pro Vega 16 4 GB
Intel UHD Graphics 630 1536 MB
16 GB 2400 MHz DDR4
    Peru Bob
    What versions of Premiere Pro, AE, and ANE?
    kglad
    p.s. i don't think the adobe website, and forums in particular, are easy to navigate, so don't spend a lot of time searching that forum list. do your best and we'll move the post if it helps you get responses.
    <moved from using the community>
