Premiere CC 2014 auto adding REC709 to LogC Amira material.
When I import Amira Log C material into premiere and drags the clips to the timeline it seems like Premiere is auto adding some sort of REC709 LUT to the footage with no options to disable it, even on export.
I want to be in control of what is happening with the footage I import and be able to export Log C sequences out without having to copy paste into After Effects to do that. Is there a sollution to this ?
