Premiere CC corrupt project files including auto-save
  • July 19, 2013
  • 12 replies
  • 69397 views
Every single premiere cc project file I have including my auto-save prj files will not load. I get the error message "The Project Appears to be Damaged, it can not be opened". This is for all my Premiere CC Projects. I have uninstalled and reinstalled Premiere with no avail. Is there anything I can do in order to salvage these corrupt files and the work/effort associated with them?
    Correct answer Mark Mapes
    Thanks, Jim--I've checked through the XML in ExtendScript (couldn't get XML Wrench on a Mac), but always get the same "damaged/outdated" message when trying to open the project again in Premiere.  (If XML Wrench has some spiffy built-in debugging thing, I'll [try to] try it, but beyond unclosed tags/basic errors, I'm not really sure what I'm supposed to be looking for in there.)
    As it is, I ended up just manually reconstructing the main sequence I needed by  laying the footage  over a fine cut export.  I'm tempted to think that another sequence or two from the corrupt project would be salvageable, though, if I could clean up the XML.  ...so the file's still up there in case someone on the Adobe side/anyone more familiar with  .prproj file structures is insanely bored and wants  another case study to dig around in...
    Sorry to hear that you're having such problems.
    One thing worth trying in CC:
    1. Create a new project
    2. in Media Browser, go to the old project. When you double-click it, you'll be able to see all the contents--sequences, bins, assets...
    3. try importing your sequences one by one. (I recommend saving after every successful import.)
    In this way, you can sometimes access most or all of the edited content in a project that cannot be opened on its own.
    Mark Mapes
    Please post one of your projects so that we can try loading it.
    Is there anything common to all your sequences--a particular clip, an effect or transition? What happens if you create a project, leave it completely empty of assets and sequences, save, close, and reload?
    If even the most basic sequence won't open, then one possiblity is that something's messed up in your preferences. To test this, try moving or renaming the "Profile-<username>" folder under Documents/Adobe/Premiere Pro/7.0.
    I tried moving/renaiming the Prefrences with no avail,... I've uploaded a zip file of the project file to the cloud. It can be accsessed here; http://adobe.ly/1bOBdox
    Thank you in advance for any assitance in this matter,
    Jennifer
    Update: A developer has investigated the project you provided, Jennifer, but was not able to find anything illuminating. So the only way we'll be able to nail this is to isolate a set of steps to create a project that turns out corrupt. The questions in my prior post should be a good start toward isolating a repro case.
    I'm also curious, since this thread began sometime around the release of the Dynamic Link 7.01 update (not to be confused with the Premiere Pro CC 7.01 update).  Have you applied that update, and if so, was it working before that update?
    I only first noticed the DL7.01 update on Monday, July 22 (I think), so maybe this isn't the issue.  I have not installed that update, yet, so I'd be willing to give your project a try... as long as it won't corrupt all of my other projects...
    Auto save overwrite itself after so many times. So if the project is corrupt all the auto save get corrupt also over time.
    Did you save a copy to another drive after every edit session.
    These files do not overwrite and you have the oppertunity to go back a day or more without loosing too much work.
    How many projects are we talking about.
    Mac or windows.
