Répondu
Premiere imports .mp4 only as audio.
Hello!
I recently updated my premiere to v.12.1.1. and now have a issue where when i try to import video files (.mp4, shot on Sony a7sII), some of the files show up just as audio.
I tried to import through drag and drop, and the import window to no avail.
What seems random is that every time i tried to import again, the files that didn't work seemed to change, i.e. the same file could one time work and the second time not.
My computers specs:
How the files look once imported:
This is truly frustrating as there doesn't seem to be any clear-cut answer to what can be done about this anywhere, and I am working on a tight deadline with this project. Any help or suggestions would be much appreciated.
Meilleure réponse par kristians91123582
QUICK UPDATE:
Found a work-around for this problem.
I happened to have the original memory cards with the source material left, so I copied the files that didn't import properly from the memory card to a different folder and imported those.
This is though a very poor fix, since I just happened to be lucky enough to have the original cards left, so can't really call this a fix.
11 commentaires
kristians91123582AuteurRéponse
QUICK UPDATE:
