Premiere pro 2020 crash while importing PSD file.
  • January 23, 2020
  • 7 replies
  • 5277 views
Adobe Premiere pro 2020 crashing when importing PSD files which were created using "Middle Eastern & South Asian" text engine in Photoshop
I am using Windows 10, 64-bit operating system.
Ram 16 GB
Hard Drive SSD
All my graphic cards are up to date
title edited by mod
Correct answer TM__
Thanks for the proposal, but I needed to keep the text editable, so I opted for the simplest solution:
- Rolled back and downloaded premiere CC 2019 version (still on the creative cloud).
- Exported my timeline as .xml
- Imported the .xml in the previous version
And all is working normally. problem SOLVED!
It is obviously a bug in the latest 2020 update, but I have due dates and cannot wait for the fix.
Hope this helps you all as well.
Best,
Toni
Clever_video5D99
Use Adobe premiere pro cc 15.2.0 (Build 35) version....Your Problem will be solved 100%
Manisoft
sound good. i test it and solved. thanks
If we do only what we know, we will never progress
i'm in the same issue ,hope to fix
i think the problem is in the font,too
adobe ,please take attention.
  • Add to Phrasebook
    • No word lists for English -> Persian...
    • Create a new word list...
  • Copy
Clever_video5D99
Use Adobe premiere pro cc 15.2.0 (Build 35) version...Your Problem will be solved 100%
The Same issue
14.0.3
any arabic text wrote with the Middle Eastern text Engine in photoshop crashes te premiere pro !
why this happen after 2 updates .. adobe doesn't test this !!!
in 2019 it was running 100% and no problems ! why in 2020 !
I am also having this exact problem.
Arabic text in .psd files imported into Premiere 14.0.3 crashes.
The original project is in 13.1.5.
I'm also having the exact same problem.
Hassanmj
If you delete text layers or rasetrize it or even convert to smart object from your PSD file you can import normally, I think there is a problem with reading the fonts layers only. try it.
TM__
TM__Correct answer
Best,
Toni
Hassanmj
Really, it's a good help Mr. Toni. Thanks for this solution. The problem is solved.
Best,
Hassan
Kartika Rawat
Hi Sham_95A!
Thank you for reaching out. I understand that Premiere Pro crashes while importing the.PSD files.
Your computer may have saved the log for the crash instances. Could you share it with us for analysis? You may refer to this link: https://community.adobe.com/t5/premiere-pro/faq-where-do-i-find-premiere-pro-crash-logs-on-windows-o...
Looking forward to your response.
Kartika
Manisoft
hi
i teach premiere pro on iran. hope help you attachment crash files for psd issue.
today many try to fix but didn't.
please if solved tell to me.
thanks.
.http://www.mediafire.com/file/ep10dkuciwep2ba/logs.zip/file
the same issue, hope anybody can help with this!
