Premiere Pro 2020 not opening projects
  • May 26, 2020
  • 99 replies
  • 44641 views
Hello! Currently I am trying to open up my premier pro projects. I am able to open the app on my iMac, but when I go to open a project, it will attempt to open, then it wont respond. I've reset my computer and restarted premiere a few times now. I'm unsure what to do next.
Correct answer Averdahl
Create a brand new project and import the old project into the new one via File > Import.
Have patience, large projects take som time to import and one can get the impression that everything has freezed.
Im having same issue  cannot open my proects, and they are only ten minutes videos.  this really sucks. I paid a good bit for this and the razer blade pro 17 64gb ram 4TB 2080 super and I7-9750H    All I want is to edit and send it.  looks like its time to eat it and go to davinci  any help??
Averdahl
Have you tried to do what i wrote earlier?
I have  ALT while launching,  copy then enter as new project  it just started a few days ago, now its useless.  why is this acceptable? its not cheap  and now I have a huge back log of videos  and an in the boc razer blade studio on my counter and Im afraid to load PP to it.  Im dying over here.
Averdahl
AverdahlCommunity ExpertCorrect answer
MichaelTCAuthor
Thanks Averdahl. This helped out. Will I need to keep repeating this process everytime I open up this project?
No, you just use the project in the new version.
