Premiere Pro 2021 Color Management won't display Arri Amira LUT no matter what
- November 3, 2021
- 1 reply
- 369 views
I run the version 15.2.0. on Windows 10 Pro.
Enabling or disabling the Amira LUT embedded with the footage through the Interpret Footage > Color Management window doesn't have any effect at displaying the LUT in the source window or in the sequence. So no matter what, I can only display the Log-C version of the footage.
I need to show the client a preview of the footage with the Amira LUT applied, so they asked me to take some screenshots from the material. But as for now, I am forced to create a huge sequence with a Lumetri Color applied to all the footage just in order to capture some screens. Exporting a frame would not help.
Oddly enough, when I switch to the icon view in the Project tab, the footage is displayed with the LUT correctly applied to it. But the moment I select a shot, the LUT disappears.
Contrary to some other users, I'm desperately trying to enable the LUT rather than disabling it. But with the same unsuccessful result: getting very pissed, Adobe. Oh yes.
