Premiere Pro 2022 Crash Fix - CoreMelt Plug-ins
I will admit that I have a lot of bloat on my machine so this may help other people who are experiencing startup crashes with 2022.
I found that CoreMelt plugins (they havent been used on my system for maybe 5 years) will crash Premiere Pro 2022 on MacOS on startup. So if you have coremelt, here's how to uninstall if you dont have the uninstaller around. https://support.coremelt.com/hc/en-gb/articles/229163687-How-do-I-uninstall-remove-CoreMelt-plugins
Maybe your system is hanging on other incompatible plug-ins, here's how to find out on MacOS: Open Library/Application Support/Adobe/Premiere Pro/22.0/Plugin Loading.log. Scroll all the way to the bottom and see which plugin Premiere attempted to load last. Most likely thats the one that crashed the app.
