Premiere Pro 2022 - Dynamic Link Not working with After Effects
  • October 24, 2021
  • 87 replies
  • 63481 views
After updating to PP 22, dynamic link with AE is not working. I've tried going to documents and putting OLD after dynamic link folder, but this did nothing.
This is so disappointing and am actually installing beta versions to finish a project.
Correct answer andz
Just an update on our side with regard on this dynamic link problem.
As of now with the latest update PP 22.11 AE 22.11 ME 22.11 , the dynamic link is working properly.
I hope also the lumetri will be fix soon.
Ill update here soon if something wrong comes up.
I'm having the same problem. I installed the old version of both, premiere and after effects and it works. The problem occurs just with the 22 version.
Same problem....It's  incredible... PREMEIRE doesn't works with Dinamik Link AFTER after the update to releas 22
Mike7385
Correct. Same issue here.
Hey Adobe, how about a refund on our monthly subscription for this garbage you release? Killed my workflow tonight.
Kartika Rawat
Hi!
Sorry for the frustration.
  • Could you confirm if both AE and AME are updated to 22.0? Also, make sure that the languages of the two versions match each other and that of their OS.
  • Disable firewall or antivirus.
  • Reset the app preferences.
  • If nothing works then clean install.
Let us know how it goes.
Kartika
So far, everything is good. I'm on Windows 10
I don't understand one thing, the developers are fixing this problem in the previous few versions. Then this problem appears after a while in new versions. The same problem is carried over after several updates. This is a worn-out topic that needs to be solved in one update and not come back to it in the future. WHAT'S GOING ADOBE?????????????
Mike7385
Louder for the people in the back!!! 👏
I have been trying SO hard to get off Adobe. I can't wait to switch to Davinci and never look back.
For what we pay for this software, there is no excuse for this.
Same problem here.
I just updated to Premiere 2022 and After Effects 2022. My Premiere project shows all of the AE dynamic link compositions as broken. When I try to import them again under the Dynamic Link menu, Premiere just stalls out, and I have to Force Quit on my Mac. Is anyone else experiencing this issue? How do you downgrade to the previous version using the Creative Cloud installer?
Terry5FF7
Yes, same problem here.
I tried uninstalling and reinstalling Premiere Pro and After Effects 2022. That fixed the problem temporarily. When I made a change in After Effects, Premiere Pro did not re-link. It just sits there with broken link to After Effects Comp.
Have to Force Quit. Dynamic Link is not working.
Same problem here. Install, reinstalled, updated OS, reinstalled again....serious dynmanic link related (I think) issues.  I usually know better than to update on the same day/week/month of an update...ugh
EnzoAlves
Hoje a Creative Cloud mostrou como disponível a atualização dos aplicativos 2021 para as versões 2022. Fiz as atualizações, porém o Premiere Pro mostrou problemas com o Dynamic Link para importar composições do After, então eu desinstalei o programa para reinstalar e testar se o problema era resolvido, mas não consigo mais encontrar a versão 2022 na CC, e com a 2021 não consigo abrir o arquivo do projeto em que estava trabalhando... alguém consegue me ajudar?
I dont see any update from 2021 to 2022 in the CC app.
If you want to downgrade make an xml
https://www.youtube.com/watch?v=eAikLdu7QSM
EnzoAlves
Não consigo fazer isso porque não tenho mais a versão 2022 instalada. Esse é justamente o problema, desinstalei e não encontro mais no CC app a versão 2022.
