Premiere Pro 2023 not recognising 5.1 surround sound audio
  • February 16, 2023
  • 3369 views
Hi
Premiere Pro 2023 not recognising 5.1 surround sound audio but it recognise 2 channels stereo audio. My pc is all working with 5.1 surround sound audio on everything else. But what's interesting is 5.1 works on Audition with WASPI, but Premiere Pro does not have WASPI.
Can anyone help?
Tim
I had the same problem and I solved it using Asio4all, you install the software and then in premiere you select use ASIO hardware, then Asio4all and that's it, it now detects all the channels. Good luck!
A question ... in the Preferences, the Audio tab, what is the 'default' behavior set for 5.1 audio?
It is set for all of them; Front, Rear, and LFE (no option for Centre).
But in Premiere Pro I only get audio from the 2 Front speakers.
Windows, and Audition give audio out of all 6 Speakers.
Mitsuperboy,
Sorry for the issue. Sounds frustrating. Did you set up audio tracks for 5.1 when setting up the sequence? Check that out in the Channel Settings in Sequence Settings.
