Jul 21, 2025 9:13 AM UTC
PREMIERE PRO 2025- COLOR PROBLEM
when I download the video, the colors are different from the one set
Jul 21, 2025 3:47 PM UTC
"We" aren't in the past, where there really was only one video color space data to work with.
Now? There's a ton as not only are there several 'major' color space options, like HDR in HLG, PQ, or a couple others, there are many cameras that have their own unique color space.
So all of this needs to have a correct transform to the color space you want to export when done.
Which is why Ishan wanted you to go to the new home of all color management in Premiere ... Lumetri panel, Settings tab ... the tab named Settings
Grab screen grabs of every section twirled down/open, and drag/drop them directly onto the text reply area so they just appear in your posts.
Then tell us what you started with and what you want to end up with. We'll get you going.
Ishan Y
Jul 21, 2025 10:04 AM UTC
Hey Federica,
Sorry for the issue. Could you share where you downloaded the video from? Please select the clip with color the color issue in the Timeline , open the Lumetri Color panel (go to the menu bar at the top, select Window > Workspaces > Color). Open the settings tab in the Lumetri Color panel and share screenshots (expand the Preferences, Project, Source Clip, and Sequence options). That will help us understand what you're working with.
Ishan
Please tag me (@) in your replies so that it notifies me and helps me respond promptly.
jane-e
Jul 21, 2025 9:50 AM UTC
@Federica_Ferron3836
Welcome to the Adobe Forums. I've moved your post from Creative Cloud desktop to the Premiere Pro forum.
Please share before and after screenshots of the change in color.
Jane
