Premiere Pro 23.3 vs Ultrastudio 4K mini
  • May 12, 2023
  • 1855 views
Hallo,
This setup: Mac Studio, OSX Monterey, blackmagic driver 12.4.2, Premiere Pro 23.3
Audio playback works fine for the Mac (through audio settings) and for Premiere Pro.
But the Blackmagic Ultrastudio 4K mini is not shown/available in the 'playback' tab of the Premiere settings to have also video output.
Any idea's? Or is it just another Adobe glitch that we have to undergo for months?
Regards, Willem-A.
Correct answer Willem-Alexan298518470xp5
this update: the trick seems to be the order of the installations:
- if you install the BlackMagic driver first and then the Adobe apps: nok
- if you install the Adobe apps and then the BlackMagic driver: ok
Also this:
OSX Monterey + Premiere Pro 23.3 + BlackMagic Desktop 12.4.1 = winning combination
Warren Heaton
Does the UltraStudio 4K Mini show under the Device pulldown menu of Blackmagic Media Express?
Does the UltraStudio 4K Mini show when you launch Blackmagic Desktop Video Setup?
Also, when you were presented with macOS prompts that either Premiere Pro or Blackmagic needed permission, did you always choose "Allow"?
Willem-Alexan298518470xp5AuthorCorrect answer
Also this:
Kevin-Monahan
Hi Willem,
I read your note and you said your device is not being detected by Premiere Pro. Another BMD user recently posted that it was working fine. You may want to reinstall the driver and Premiere Pro to see if that might fix the issue. I hope the community can help you with a fix.
