Premiere Pro 24.0 Crashes when Exporting
  • October 9, 2023
  • 5 replies
  • 5709 views
Hello everyone,
Basically what the title says. I've opened a project I was working on and it converted it to Premiere 24.0 version. When I tried exporting a clip it crashes, every time. I tried uninstalling and installing but nothing worked. Any ideas?
Thanks in advance.
I have the exact same problem. Regardless of the exporting format, Premier Pro 24.0 crashes on every attempt to export. I am on my school issued M1 Mackboo Pro 16". I have also contacted the Technical Support at Full Sail University and their best resolution was to uninstall 24.0 and revert back to 23.6. After doing that, I have no more issues.
I had the same issue with the same computer as you. My work around is that I send it to Media Encoder, I then change the "Renderer Settings" to Software Only. that's what got it working for me.
Try the following:
. Delete the render files from sequence, or the video previews folder.
. Export to QuickTime (something like Cineform or ProRes)
. Clean media cache.
Ari2leAuthor
When I try exporting it from Media Encoder I get this error:
Export Error
Error compiling movie. Accelerated Renderer Error
Unable to produce frame.
Writing with exporter: H.264
Writing to file: /Volumes/DGK Music/Sequence 01.mp4
Writing file type: H264
Around timecode: 00:22:50:42 - 00:22:50:51
Rendering at offset: 688,933 seconds
Component: H.264 of type Exporter
Selector: 9
Error code: -1609629695
jstrawn
What format are you choosing to export with? A screenshot of your export settings might help.
Does the export succeed if you send it to Media Encoder and do the export from there?
Ari2leAuthor
I'm currently using a Mac Studio M2 Max.
OS: Ventura 13.4.1(c)
