Apr 16, 2025 3:59 PM UTC
Premiere Pro 25.1.0 When labelling section of clip with a color, whole clip turns the same color
I have one multicam clip with several through-edit cuts. I wanted to color one of these sections with a color label, but when selecting such label, ALL of the through-edit clips turn into that color label. There's no way of coloring just one section. Attached is a video showing what I mean. This is a bug that should be fixed, Premiere should treat every through-edit as an individual cut when it comes to color labeling.
My computer settings:
MacBook Pro (16-inch, 2019)
2.3 GHz Intel Core i9 8 nucleos
32 GB 2667 MHz DDR4
Macintosh HD
AMD Radeon Pro 5500M 8 GB
Intel UHD Graphics 630 1536 MB
Adobe Employee
Apr 16, 2025 7:22 PM UTC
Hi maiathesun,
Welcome to the community! Please click on the option for Timeline Display Settings (the wrench icon on the timeline) & uncheck Show Source Clip Name & Label. Once done, check if you are able to label individual sections of the clips. Hope it helps.
Sumeet
