Feb 9, 2025 8:10 PM UTC
Premiere Pro: Adding a Custom Preset to Audio Track Mixer
Is there a way to add a custom preset to the audio mixer? I know you can add each individual portion of the preset, but that also seems to be limited to 5.
Premiere Pro V 25.1.0 (Build 73)
Mac M1 Max 64GB Ram OS 15.3
PaulMurphyCorrect answer
Feb 10, 2025 4:48 AM UTC
Unfortunately, the Audio Track Mixer does not support custom effect presets for track-based effects.
That said, you can copy individual effects along with their settings to other tracks by holding down Alt (Windows) or Option (Mac) and dragging the effect to another track’s effect slot.
Each audio track is limited to five effect slots. However, you can work around this limitation by routing the track to a submix, where you can apply additional effects as needed.
PaulMurphyCommunity ExpertCorrect answer
kglad
Feb 9, 2025 8:18 PM UTC
<"moved from cc desktop">
