Premiere Pro - Audio doesn't work
  • July 2, 2018
  • 1766 views
I didn't have any problem with audio before, all this internet advices don't work, delete cache etc. First problem I had is I placed my file on the timeline, I had audio track for this file but it was empty for some reason, on the internet some people imported file with no audio track at all, I have a track its just empty, wat I did, i moved and renamed file, it was fine, but later even if I had normal audio track, suddenly it stopped playing, First time - ok, second time playback - ok, and suddenly third time does not work, even if timeline says there is audio track, does not play anything. I tired to turn off it 1000 times, computer/Premiere pro
No it is not audio hardware settings problem.
    Correct answer marcino91428828
    Yes and No, Yes because I did not solve the problem, No because I recorded it again, it was a filmic pro problem, Priemiere pro doesn't support sth from this app, when I used DJI app everything was fine.
    Really bad premiere pro!
    Thank you anyway guys!
    Still having this issue marcino? Please let us know.
    marcino91428828AuthorCorrect answer
    Definitely try a different audio format in FilmicPro. That may solve it.
    AbdalaBrothers
    bro, this may sound ridiculous, but its the way to fix it, happend with me too, you just mute the track while playing or click on “solo” and take it off again, for now on the audio will be just fine
    great ! yeah happened with others as well ...
    The best practices to this so far besides cleaning media cache from time to time,
    you have to delete the 'Audio Previews' as well
    If cleaning media cache and audio previews do not work, consider troubleshooting
    your hardware, update drivers, or the OS ...
    You can refer to Jim Simon's most common issues and troubleshooting :
    Unofficial Premiere Pro Troubleshooting Guide
    How to delete audio previews? I am using Mac
    Inside premiere go to Sequence - Delete Render Files or File - Project
    Settings where you can see the path where your audio previews are saved
