Premiere Pro Audio preview files missing in its home folder but audio is still working... HELP!
  • May 1, 2024
  • 6 replies
  • 1266 views
Hi.
I'm currently in the middle of editing a project on Premiere Pro 23.4 and I just noticed that my audio preview files folder is empty - BUT everything (sound) is playing without needing renders. Normally if files dont exist, they need to be generated. I have no idea how all the footage in my project is working without preview files, but I have nearly 2 Terrabites of footage in multiple sequences. I'm quite advanced in this project  and I'm now concerned that I will have issues later on and I can't miss deadlines. I've checked scratch disk locations and prevews are set in my original project folder, but nowhere to be seen...EMPTY ! I tripple checked and there is nowhere else these could have gone.  This makes no sense. Nothing gets generated, yet all is working as it should... I even duplicated the project and reset things to see if that would change things, but no avail.
I don't want to restart as I've got over a week of work done already.
Anyone have  a solution or answer to this??? I'm concerned this will bite me in the bum when it comes to finalizing as these files should normally exist. Is there a way to force generate sometjhing like that. Hust hitting render audio isn't a solution. I tried already.  Confused as to how things are playing.
Help!
TIA
Peru Bob
Can you post screenshots of your project settings and of the location of where they are not showing?
Shure thing. Here are two grabs. It says "custom" but it's the same location as the project if you look at the path.
I have the same problem @Kevin32095894chod is experiencing.  Was there any resolution to this?  My scratch disk location is the same (Custom folder location).
kglad
<"moved from cc desktop">
