Premiere Pro audio stuck after Voice Over recording via "capture"
after upgrading my system to APP 13.1.5, everytime I record an audio via Capture/Audio and conclude the recording closing the capture window my audio get stuck.
Basically I can see the waveform from the new created file and also for any other audio in the time line, but when I press play, audio is mute and the audio meters shows are blocked and show all channels at a fixed level (they don't move).
Tried to mute/solo audio tracks, play different files but it remains like that until I reboot the system.
Any idea how to fix it?
By the way, never had this issue with the previous version; APP CC 2018.
Using: Adobe Premiere Pro CC 2019 13.1.5 on an IMac OS High Sierra 3,2 with 32 GB memory.
