Premiere Pro bugs
  • January 21, 2026
  • 127 views
Hello. There are a few bugs that have been around for a few months now.
The worst one is that when I'm editing text, the keyboard shortcuts aren't disabled as they should be, and they were before. So while I'm typing random letters it does all kinds of actions that it shouldn't do. Like take me to the beginning or the end of the timeline when typing "i" or "o", etc. These should be disabled when we are typing text and the text tool is selected. The output is completely random; a few times you type those letters and everything is ok, but then most of the time they activate the keyboard shortcuts and sometimes it types the letters, sometimes it doesn't. I can't believe this bug hasn't been solved yet. I do a lot of videos with significant text and this bug is extremely frustrating.
And another bug I wanna report happens when copying different elements on the timeline that have the FilmImpact effects. For instance, I copy a text that has the Block Motion effect a few times and then suddenly, some of the duplicated elements contain a cross dissolve effect instead of the block motion one. Again, completely random and ilogical.
Thanks for reading this and please fix these bugs.
jamieclarke
Hi @Dan31837810mhco - the first issue you are describing where keyboard shortcuts are overriding text input has been fixed in Premiere version 25.6: P: Shortcut keys overriding while typing
Can you post your reproducible steps for your second issue, or share a screen recording.
Thanks for the reply. I have the last version, 25.6.4, and the bug still persists.
Stan Jones
@Dan31837810mhco,
If you reset preferences as Jamie suggests, I would also clear the cache. And reset your workspace to the saved layout.
There were 3 bugs that could create this symptom. One is no longer possible, because it involved the reference monitor which has been removed. I just tested the other two in 25.6.4, and they are not present.
In PR, check Help -> About to confirm the version you are in. If you are seeing this problem, it would help to have a screen recording.
What operating system?
Stan
