Premiere Pro CC 2015 auto selecting clip under playhead?
  • June 16, 2015
  • 7 replies
  • 46926 views
I've noticed PP CC 2015 is auto selecting the clip below the playhead at all times (therefore effects controls change to wherever the cursor is).  While useful sometimes, I have not found a way to turn this feature off.  Anyone else having this?
Correct answer Trent Happel
Under Sequence menu, uncheck Select Follows Playhead. This was added with the new Lumetri Color panel workflow and is enabled by default if you have this panel open.
Bracker360
Thank you! Super helpful to know that. I find that follow playhead highlight feature incredibly annoying.
Awesome. That was driving me nuts.  Couldn't quickly speed through my clips monitoring the audio with that highlighted.
Thank you for this thread on how to turn the feature off. It was causing me so many extra clicks just to delete a segment, and segments were inadvertently getting deleted from my timeline when I didn't realize they were auto-selected. I can always turn it back on for color work. So glad I found this thread.
Most annoying feature ever.
DrTc
Is there a way to make Pr auto select the Video track instead of the audio track under playhead?
Lock the audio track:
MtD
cliffclof
Great!  next time offer the feature, but please don't force it.
For the color grading process I can see where I would enjoy having this feature turned on...but for general editing, it was driving me bananas and slowing me down tremendously when trying to do keyboard shortcuts to add cross disolve transitions between clips on a longer live event edit.
For other people that might be finding this frustrating as well and not be fortunate enough to find this thread, I would recommend this only be set to ON by DEFAULT, when someone specifically launces their COLOR WORKSPACE. Then in the EDITING WORKSPACE, by default, the option would be turned off.
Snemanje poroke
Right.
As I love this feature (I always wanted keyboard shortcut for clip selection) it drove me nuts when making default transitions and when color corecting - I usually have "adjustment layer" on top-most video track - so one extra click on empy space before any opration.:(
THANK YOU ADOBE for giving this as an option. That is the correct way of adding feratures.
What drives me even more crazy is way of adding default transition itself. It won't add it if something anywhere on timeline is selected. It won't add it even if previous transition (which was clicked and adjusted) is selected. Or it is adding it somewhere out of sight on some clip(s) which are left selected - ruining previous editing and/or wasting time to figure out why the heck transition is not showing up at given cut. Having transitions all over place sometimes is spotted only after rendering out and reviewing the final render. Ouch I HATE THIS. Let alone it bugs me that white selected empty track trhoughout all sequence.
Does anyone else hate this "feature" of Premiere CC?
I loose time, have to do extra thinking/clicks, findig empty space to click it is sometimes tricky on busy timelines, making undos (checking if something was happend when "nothing happend at clicking CTRL+D), ... I edit with Premiere from version 6.5 and all "pro" versiona as well. I used to train people for Avid and Incite and worked on Liquid as well. So quite some systems. This feaure is time killer like no other (and yes, it saves time when U need transitions on all selected cuts or titles - so 1 step further, 10 back). If software need special attention all the time, not to mess upp something, than this is no PRO software. Such a small feature can ruin productivity.
I would like the voice of others.
Richard TOULON
I also hate this:
Did you find a solution??
Thanks
Felipe
Hi felipe, maybe you should have inserted the beginning of the original message from Snemanje Poroke. He is talking about transition.
I don't really understand the problem. If a cut is selected, just push Shift + D  ( PC ), You want to add transition on a single clip at in and out, Ctrl + Shift + D . Add default transition to multiple clips . Select any clip you want and repeat the process. Does it help ?
Trent HappelCorrect answer
I rather love this myself.  Makes grading much easier.
