swmp
Premiere Pro CC 2018 - AVCHD no audio
  • October 18, 2017
  • 62 replies
  • 33933 views
I installed the 2018 version and when importing AVCHD clips (via media browser) no audio tracks where recognized.
In the 2017 version (runs parallel) the import works without any problems.
As with the latest updates, there is also the problem that when opening projects of the previous version the AVCHD clips are all offline.
The old tried and tested tricks like delete mediacache, rename clip folders and rename common folders do not work.
I can re-link the clips, but then get the error message that the audio tracks are faulty and can not be imported.
Any suggestions?
    Correct answer Trent Happel
    Adobe Creative Cloud has moved to native Operating System (OS) support for Dolby Digital decoding (reading Dolby files) and is no longer providing support for encoding (writing) Dolby Digital and Dolby Digital Plus sound formats in the current and future releases of Creative Cloud.
    Dolby audio decoding
    Both Windows and OS X operating systems (Windows 8.1 or above and Mac OS X .11 or above) contain native support for Dolby decoding functions. Please update to the latest version of your operating system.
    Dolby Audio decode support for Windows operating systems
    If you run a Windows operating system on your computer, all recent versions now support some form of Operating System (OS) level decode for Dolby audio.
    There are a few exceptions, though:
    Older versions of Windows:
    • Windows 7: Windows 7 does not include the media package required to decode AC-3. The best solution is to upgrade to Windows 10.
    Adobe Creative Cloud apps use native OS support for Dolby
    This fellow's solution worked for me: missing dolby audio decoder premiere pro cc 2018-2019 - YouTube
    I am using windows 7 and I find it very unacceptable that software companies are trying to force us to upgrade to new operating systems.
    ProDesignTools
    That "solution" is using a pirated copy of a third-party plugin coming from unknown origin, downloaded illegally via a random link from an unauthenticated file repository... Definitely not recommended (or safe)!
    Regarding still using Windows 7, are you aware that it will reach end-of-life and become unsupported by Microsoft (i.e., no further updates or security patches) in January?
    https://support.microsoft.com/en-us/help/4057281/windows-7-support-will-end-on-january-14-2020
    Hello, thank you very much for that information. I did not realize it was
    pirated software. I did know about support ending for Windows 7 however.
    Thanks again for taking the time to inform me.
    On Thu, May 30, 2019, 11:22 AM ProDesignTools <forums_noreply@adobe.com>
    What worked for me perfectly was this: I downloaded the free HandBrake program. It is a file converter. I converted the .MTS files to MP4 very easily in this program. And now I have the audios.
    glauxtheowl
    Sorry Gabriel but I think you are missing the point here. We are looking for a solution that will avoid re-encoding the files and losing quality. MP4 in particular is a majorly lossy format so I would definitely not recommend that. Besides, some people (like myself) have hundreds of hours of footage that would need to be converted, so that's simply not an option.
    If you are going to convert files one by one, I have already posted a solution that works better: using Avidemux to only re-encode the sound track as MP3 and remux it with the original video. You will lose sound quality, but at least video quality is preserved.
    The real solution has to come from Adobe, but I think it's become clear that they don't have their customers' interest at heart so they are not going to fix this any time soon.
    danielp73653478
    For those of you still struggling with this, I found a solution for me in a different thread. In Mac system preferences, go into the Perian Preferences Pane, and uninstall it. It's a Quicktime plugin that is no longer supported. That fixed AVCHD/MTS audio import issues for me.
    FTSA_-_Teologia
    Friend, I had several times this type of problem, in my case I had problems with recordings of long durations and more than one camera, and when I was in the middle of the editions one of the files started reproducing an audio that was not his, I found strange what happened and I discovered that it took the same audio from a file that contained the same name, and Premiere had to get confused in the encodings and mixed the audios. To solve it was easy, just renamed the files I had problem, I expected it to appear as '' Offline '' in Premiere, and I sent '' Locate media '', problem solved.
    That's interesting. I ran into a similar problem with a mutlicamera project, where one of the cameras is a Panasonic GH2 that saves in MTS format. I imported it into Premiere with a proxy, and sure enough, the proxy's audio would go waay out of sync. (Using originals gave me decent audio.)
    Not a huge problem, and I found that creating copies of the originals and importing _those_ with proxies seemed to work. So maybe the name issue's at work here, too.
    March 12, 2018
    for anyone who has been through the steps provided by adobe after removing the native Dolby codec, and still have had no luck in having the sound file reappeqring on mts files I would advise against converting the entire video file due to the time taken to do this. Instead use VLC to convert the file to a lossless audio file of the same sample and bitrate of the original audio (there are tutorials to do this), import the audio into premiere and then merge the video and audio into one clip...i found this to be the easiest and quickest work around.
    glauxtheowl
    Thanks for the suggestion but this is absolutely NOT the easiest and quickest work around! Merging video and audio for each individual clip, in a project where you might have tens of different clips, is simply not practical.
    I am going to offer my own solution, which is still not ideal but is better than being forced to upgrade to Windows 10, or being unable to update Premiere forever...
    Load the clips (MTS in my case) into Avidemux (free), leave the Video option as "Copy" (for quick and lossless conversion) and change the Audio to a different format. I chose MP3 but there are many others which Premiere will happily work with.
    Then change the output format to MKV and save. Do this for all clips in your project folder, it doesn't take long at all (a 40 minute, 1.9 GB MTS file takes about a minute to convert on my machine). Then move or delete the original MTS clips from the project folder.
    Next time you open the project in PP 2018, it will prompt you to locate the missing files. Assign each missing MTS file to the newly created MKV version and you're done. Sound is back on and your projects need no modification.
    spece96285799
    Here is the real solution: NO SOUND In Premiere CC 2018 - Fixed QUICKLY - Thanks GOD - premiere not importing audio - YouTube
    Quit Premiere. Rename the adobe/Common directory in your library. Premiere will build a new common directory. Works on Mac too. We just tested this out.
    The second video has audio on import all he has do is source patching.
    It's real simple - Adobe has customers paying a license to use a specific feature set of tools.
    When Adobe suddenly makes a change to those tools relied on by their customers, then Adobe needs to explain why they have made the sudden change/removal of a tool.
    This is getting to be a bad pattern in the Adobe infrastructure:
    - Speedgrade gone - Lumetri is no where close to being capable of what Speedgrade could do for color grading
    - Dolby encoding gone
    - Story going away
    And did anyone see any reduction in the license cost for reduced tool set?
    Averdahl
    Due to a bug in CC2018 when opening a Sequence in the Source i installed CC2017 so i could continue in CC2017 but all AVCHD imports without audio despite that i am using Windows 10, v1709.
    What a disappointment, despite being on a supported OS CC2017 import my files without audio and i cannot continue.
    ProDesignTools
    Hi Averdahl,
    If you downloaded Premiere Pro CC 2017 recently, then Adobe had to remove the Dolby codec and republish their installer without it – so it is no longer present there.
    And CC 2017 will not use the Windows/Mac operating system support; only CC 2018 will.
    But Premiere Pro CC 2018 just received an update last week to version 12.0.1 – perhaps that might address any issue that you had?
    New features summary for the January 2018 and October 2017 releases of Adobe Premiere Pro CC.
    Mickeyfilm
    I'm totally frustrated. For most of the past 7 years I have used Adobe, and for 10 years prior to that, Avid. I have some very long-term feature-length docs. I upgraded to High Sierra like an idiot. High Sierra doesn't recognize any of my many .mts files. I was also an idiot for upgrading to Premiere 2018. I've lost a huge amount of edit time now. What do I do? Adobe really upset me when I finally got someone on the phone. They simply blamed the Apple OS. I can't find an answer anywhere. If I go back to "Sierra", do I lose everything on my main drive? I've never done that. I'm completely at a loss and I've spent days reading discussion boards. There are literally thousands of editors who are having this problem and Adobe doesn't seem to understand this.
    ProDesignTools
    Sorry to hear of your troubles. If you're running CC 2018 and the latest version of macOS, and still can't use Dolby decoding, did you try all the suggestions given at the top of this thread – such as cleaning your media cache, as well as renaming and reimporting your MTS files, etc.?
    Has this problem been solved yet?  I still have Windows 7 and CC 2017.  I am reluctant to upgrade either one, especially Windows, due to problems experienced in the past.  Plus, I just don't like Windows 10 at all.
    Adobe wont fix this for you, your only option is to upgrade to W8 or W10.
    Having the same problem. I was using Windows 7 and PP 2017, mainly because PP 2018 wasn't dealing with my MTS files at all. Neither the audio nor the video would display. I tried the various fixes under Windows 7, with no luck.
    So, I just upgraded to Windows 10 Professional. Opened my project in PP 2018... and yes, the MTS files are still "media missing." Emptied my cache. Tried re-importing the files. No luck at all.
    Any suggestions?
