caran31796251
Premiere Pro CC 2018 Won't Launch
  • January 4, 2018
  • 9 replies
  • 47046 views
Within the last two days Premiere Pro CC 2018 stopped launching, or if it did launch, would freeze on the splash screen, project screen, opening a project, or loading a project.
I have uninstalled/reinstalled, ensured PC software and drivers are up-to-date, restarted the PC and still nothing. I've ended every CC process and relaunched, but still nothing. I can't even open it by clicking on recent projects that I was working on two days ago. I'm not given options to send crash reports to Adobe either.
How can I get Premiere to launch/work properly again?
I'm using a Microsoft Surface Pro 4 with an Intel Core i5-6300U CPU @2.40GHz 2.5GHZ, 8GB of Ram, 64-bit operating system, running Windows 10 Pro.
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from CS6 & earlier Creative Suites to program forum... Mod]
Correct answer caran31796251
Hi Kevin,
Yes and no. I can launch it but only in windows 8 Comparability mode. I normally run windows 10 Professional.
So, I kinda solved it but it feels more like a band aid than a full on solution.
thanks,
Cara
im having the same problem. when i click on the shortcut nothing happeneds
Hi I have had the same problem as you and I was able to fix it and all I did was I opened up task manager and I right clicked on premiere pro and ended process and opened premiere and it was fixed.
Azure Mirage
Thanks, gamerboy022! Having the same problem a year later, and this is the fix.
I am not able to launch Premiere Pro either.  I work on a PC with Windows 7 Pro.  I am a Creative Cloud subscriber and cannot launch Premiere Pro CC.
It is urgent that this is resolved as I have client projects to complete.
antonylau123
here also, just update the Premiere, but not can't open... i have clean the preference and reinstall 2 time, still only have the splash page and then turns off too. please faster update for this bug, need to hand in works......
mas OS 10.13.4
Vinay Dwivedi
Adobe Employee
Adobe Employee
April 13, 2018
Hi antony,
Have you tried the steps mentioned in the below KB?
Let me know if it helps.
Application crashes during launch on mac OS
//Vinay
I’m on windows 10 not mac. I don’t know how to follow those steps on windows 10
Sent from Yahoo Mail for iPad
acitron1960
I'm on a Mac and I can't launch Premiere as well. I opens to the splash page and then turns off.
Somebody please help.  I'm having the same problem.  I'm using Windows 10.  Everybody started talking about it on mac...but I need a solution for Windows 10.  I've tried launching with alt+Shift...nothing.  I need help!!!!
digitalseer
Having the same issue on a Mac running Sierra 10.12.3. Just updated to the latest version of Premiere and the application won't launch. It bounces a few times, shows the load screen for 2 seconds then stops.
It would awesome if y'all could release one version of updates without immediate bugs.
Kevin-Monahan
Hi CaraN,
Are you still having trouble launching the application?
I have this same problem, im already reinstall, change the name of "adobe" carpets, restart my macbook, reinstall all the adobe cloud.
Helpme i need to work
Same here. The most recent PP update wont open on our end as well.
this worked for me:
2. Backup the Preferences before next step(~/Documents/Adobe/Premiere Pro/12.0/Profile-USER)
3. Rename the following list of folders to Old_foldername.
   ~/Library/Caches/Adobe/Premiere Pro/12.0
   ~/Library/Preference/com.Adobe.PremierePro.CC12.plist
   ~/Library/Saved Application State/com.Adobe.PremierePro.CC12.savedState
Note: All the above folders will be in the hidden library. Here are the steps to access it: Access hidden Mac OS library files
4. Empty trash
5. Reboot the machine.
kulpreet singh
Hi caran31796251,
Launch/open Premiere Pro by holding down shift + alt until splash screen.
Let me know if that helps.
Kulpreet Singh
I am having this same issue as of today. Restarted, held down shift + alt... nothing is working. App is up to date as well.
Ideas?
digitalseer
This seemed to solve the problem so far - Premiere Pro cc2018 won't start anymore after latest update
As CRAIGVFX confirmed, the steps listed worked for me.
