ChristianFluher
Premiere Pro CC 2020 and BRAW errors, URGENT HELP - stuck in the middle of project
  • November 6, 2019
  • 6 replies
  • 10138 views
Updating Premiere Pro to CC 2020 made a lot of crashes and errors. I have some braw footage and some of them I am able to import, and some random ones I cannot (menia offline - trying to link it: The importer reported a generic error.) I have no idea what to do, to import braws. I cannot end my project now.
If it works ... stay with it! Right.
If not, there is an alternative. Ain't this all a joy? Sigh.
afdambrosio
I had the same problems and switched to the thrid party plugin, and this fixed the issue thus far. thanks for the advice
OstiaAlex,
Sometimes ... you get what you pay for. The BlackMagic freebie BMRAW plugin works ok ... mostly ... sort-of. Personally, I'm not a big fan of mostly-sort-of.
There is a plugin called BRAW-Studio made by Autokroma that of course you do have to pay for. I suggest trying that one, and paying the small fee for using it each in Premiere and MediaEncoder ... for two reasons:
  • It has a preset-setting option available, which is VERY useful;
  • It ... just works.
I too have had spotty issues with the BM freebie. The Autokroma one just works. At least for all my BMRAW media. So ... try that, see if it gets the job done. And btw ... I actual purchased my copies via aescripts.com ... which is a handy site with a ton of plugins for the Adobe apps to peruse through. And buying a plugin from there gives you a process for updating and such within their site. Very handy.
Thanks Neil. Actually I just found the latest Blackmagic RAW 1.6 and since I've just installed that things have improved massively. Only one crash now in a few hours and everything else seems to run smoothly.
Getting better, so they must be on it.
Cheers,
Alex
How has 1.6 been working for you? I installed 1.6 and now I can no longer import .braw files into Premiere 2020.
Josh,
Which plugin are you using?
I've got both the latest BM plugin ... 1.5.2, and the latest Autokroma plugin installed. Both are working without troubles on my Win10/6-core system, though I prefer the Autokroma plugin because of the presets options there.
BRAW Studio should work well in CC 2020 in its last version (1.8.0 released today).
We discovered that some braw files can't be imported into PPro with the Blackmagic RAW plugin 1.5.2, but we don't know yet what this files have in particular.
Nicolas from Autokroma team
Having the same issue. I'll be editing my braw footage and a couple of things are happening constantly:
1. My entire computer crashes.
2. I will double click on a clip and Premiere freezes and gives me the rainbow wheel until I have to force quit.
Same for me. Whole folders full of BRAW 6k can import and play fine, but then some folder and/or individual clips don't import (error on import module) and then sometimes when I play a clip it freezes PPro20 and I have to force quit. Just about to dive into a big edit with my producer next week and this will kill me as we have a very tight deadline.
Anyone?!
Go back to 2019 and finish the project before embarking on 2020 with a fresh project.
ChristianFluher
same problem on previous version of PP from now on 😞 continuing on other comp
vii777
I had the same problem using Autokroma codec for braw after 2020 update. Uninstalled autokroma, downloaded and installed Blackmagic RAW 1.5.2 off their site (released not too long ago) everythings peachy. Hope this helps!
ChristianFluher
've been there, 've done that 🙂 nothing helps, also clean install of program didn't help...
