Premiere Pro CC Encoding Failed A low-level exception occurred in: Lumetri Color (AEVideoFilter)
  • June 26, 2015
  • 47 replies
  • 92532 views
Trying to export video to DVD format (MPEG2-DVD).. It starts to render video "normally" up to 10-50 minutes.. Tried multiple times, changed video quality and changed output drive, always interrupting with same error code..
Is there something to do..?
- Encoding Time: 02:22:33
06/26/2015 09:40:48 PM : Encoding Failed
Export Error
Error compiling movie.
Unknown error.
Correct answer Kevin J. Monahan Jr.
If you have a solution that you found, please return to the thread and let us know. We can only assume that you solved your issue. Typically, one will get these kinds of errors when you've exhausted system resources like VRAM, system RAM, or both.
The solution or workaround is to use Software Only mode for the Mercury Playback Engine. You can also purchase additional hardware which may assist the job.
Same problem.  And, strangely it went from only being on a few points in a file last night, to covering most of the video file tonight after coming back to it.  With this kind of bug, there really needs to be help in how to address it so that these files are usable.  Windows 10, latest Premiere Pro.
same problem here.
Mac OS X 10.9.4
Latest CC
Countless Errors while using the warp stabilizer
"A low-level exception occured in : warpstabilizer (AEVideoFilter)"
mistigrif51231268
same here...
I´ve got same Problems.
Windows 10
Latest Premiere CC
RED 4K Footage
Only Effect used is Lumetri-Color and I scaled the video to fit in 1080p. No LUT applied.
Countless Errors:
Adobe Employee
September 30, 2015
Are your graphics card's drivers up to date?
Fran
mistigrif51231268
Hi, yes mine is
Dennis Weinmann
Adobe Employee
Adobe Employee
July 28, 2015
Can you please share a couple of additional information:
- OS
- GPU (OpenCL/Cuda)
- Where is the LUT coming from: External imported, pre-installed
- LUT format
- Where have you applied the LUT (Basic/Creative/Export)
- Any other effects applied ?
Thanks.
Dennis
No my 30-day trial just passed, a bit too late, sorry.
Terveisin,
Antti Lehtinen
Sound-IT Media / Uurasdata
[personal info removed by moderator]
I have the same thing. When I try to apply any video transition that is not a simple fade.
I got the same error when loading up a project with lumetri colour applied and a LUT set in there - buggiest PPro release ever
Eamo Quinn
I'm getting the same error in the editing timeline in CC2015... Only occurred when LUT appiled.
No problem in export though.
Following this thread to get an answer (hopefully!).
did you solve the problem yet?
Thanks for question, already yes.
I used Premiere trial on Windows 8.1. Deleted. I think i will roll on a Mac
in near future.
Too much troubles on win.
Thanks again, Emily.
2015-10-23 18:36 GMT+03:00 emily swe <forums_noreply@adobe.com>:
Color (AEVideoFilter) created by emily swe
<https://forums.adobe.com/people/emily+swe> in Premiere Pro - View the
full discussion <https://forums.adobe.com/message/8099086#8099086>
