Premiere Pro CC, Project / sequence settings help with GoPro 1080p / 60fps
  • May 18, 2014
  • 31501 views
Hi all,
I have just started using Premiere Pro CC with the GoPro Hero3+ black edition, but my video's, once exported do not look very smooth and clean like HD video should?
The video settings on the GoPro are 1080p / 60fps, narrow view (protune off), I then import these .MP4 video files into PP CC and use these sequence settings:
29.97fps
1920 x 1080 / 16:9
Square pixels (1.0)
No fields (progressive scan)
30 fps drop-frame timecode
Preview file format: I-Frame only MPEG
Maximum bit depth
So, my question is, should my sequence settings be at 60fps to match the 60fps I used to capture the video with? How should I edit 1080p / 60fps video in order to get nice clean, smooth HD video playback on youtube?
My export settings are:
H.264
1920 x 1080
29.94
Progressive
Square pixels (1.0)
NTSC
Profile: Main
Level: 5.1
Render at maximum depth
VBR, 2 pass
Target Mbps: 40
Max Mbps: 50
Keyframe distance box checked and says: 90
Use maximum render quality
Here is the video I uploaded to youtube: Deal Tri Summer Duathlon May 2014 - YouTube
What do you think?
Any help would be very much appreciated!
Kind regards,
Paul
    JosgarSc
    Hope you solved your problem, and I'm hoping you can help me with mine. I have premiere pro cc to, but I don't have any sequence presets for 1080p30 and I really need it, so I don't know if you know how can I get it or something like that. Thank you very nice. Have a nice day.
    gsxr1paulAuthor
    Once you have created a new project, import the video(s) into your project, then click and drag one of your videos onto the 'new item' folder. This will create a new sequence based on your video...so if your video was recorded in 1080p at 30fps then the sequence will match your video automatically. After you have done this, go to sequence settings and double check...
    JosgarSc
    Thank you very much. So simple, and couldn't do that before lol You've helped me a lot.
    Yes.
    I'm not sure you can.  I believe YouTube won't go over 30p.
    youtube now support 60 fps. But how export 60 fps video from 60 fps footage? I create 60 fps timeline, but video playing in 30 fps. Even footage is playing in 30 fps
    Putting a screen grab capture of your sequence setting would help us. PrPro can both edit and export 60fps.
