Premiere Pro encoding Problems! Please help as fast as you can!!
  • September 11, 2018
  • 919 views
When I encode a Raw Video from OBS in Premiere Pro everytime it gets grainy and I don't know what I can do!At first you can see my Sequence Settings, after that there is the Raw Video Properties, the third Screenshot is a frame of the Rendered Video with Premiere Pro and at least there is the Raw Video! Please help guys!
    Jeff Bugbee
    Change your OBS encoding settings from VBR to CBR. Premiere does not handle VBR footage well at all. Like Ann said, your current footage you can re-encode in Handbrake to CBR. That should resolve your issue.
    Richard van den Boogaard
    You probably need to adjust the encoding bitrate.
    Export video from Premiere Pro with Media Encoder |
    evenex.Author
    When I put the encoding bitrate higher it looks like before
    Might want to run the file through Handbrake first and set it to constant framerate before bringing it into Premiere.
    In your sequence settings turn off
    Max bitrate
    max render
    composite in linear color.
