Premiere Pro √er 15,0
  • March 13, 2021
  • 957 views
Hello all, I am working in Premiere Pro V15.0..... I am setting my settings for exporting. Then I look and see the thumbnails in the folder they are saved to, I then see black bars above and below. Some are all the way around the image. I am filming in 60 Fps HD. I am uploading to a client who says that I need to remove the black bars to be excepted. These are samples of what is being shown to the client when uploaded. I have to remove the black bars in order to be excepted. I am stuck. Can anyone give me some help with what I need to?
Thank you,
Bill
Use "Set to Frame Size."
Good morning  Justin,
Yes, these are imports, exports, and rendering in Adobe Premiere Pro V15.0. here are the screenshots....... Ok, they are here. If you can is there a video tutorial I can watch for steps to follow to get it right. The originals were all done at 60 fps at 3840 x 1620. I will have to pick one and redo it with screenshots too.  thank you so much for your response.
Bill Hirsh
The train is scale up to fit the frame, the kitchen has a black border meaning
the sequence settings does not match the source.
Post screenshot of properties train and kitchen.
here you go
That is your answer.
Your footage is 1280x720 and your sequence is 1920x1080: they dont match. Hence the black border.
Go into your sequence settings and change height and width to 1280x720.
That should fix it. You do need to check all image for the correct scale.
(Set to framesize as Michael suggested is imo not an option. It will scale up footage far too much and you are dealing with a client who wants max image quality for sure.
PS turn off max render on export if you have a dedicated gpu.
Justin Taylor-Hyper Brew
These are exports from Premiere? Can you send screenshots of your sequence settings and export preset settings?
Hi Justin, this is the original footage settings in Pr 2021 v15.0...... Again, Thank y9ou for any help you may provide me. It is nice to learn new things for your passion.
Bill Hirsh
This train shot looks fine to me, no added borders.
Can you post a screenshot of the kitchen sequence with the timeline? That one either has to be the wrong scale or you're using a proxy file with different dimensions.
