zykhil
Premiere Pro - Huge Workspace Resolution Problem
  • May 19, 2017
  • 4988 views
Hello , I have been using different versions of Premier since a long time but never faced this problem.
Ever Since I subscribed to the new Adobe Premier Pro 2017.0.2 v11.0 , my workspace has become very huge
and most of the editing space has become very less flexible(screenshot below). My screen resolution is at
a maximum of 1920x1080 (which im used to and very comfortable to work with)
I must mention that I have faced similar issue with my Photoshop CC but once I updated to the latest version ,
it is able to adjust itself to the maximum resolution and works like a charm(screenshot below)
It was a very frustrating experience that Photoshop was able to adjust itself to my resolution by default but premier isnt (earlier versions of premier pro used to adjust itself too). I have tried chatting with tech support and googling several forums but in vain. The tech support even logged into my laptop remotely to resolve the problem and were asking me to adjust my main screen resolution , which would mess up my other apps and doesnt look aesthetic to my eyes , another tech support person said , premier cannot adjust like how photoshop does (I mean I have literally worked on it and saw how it adjusted). I cannot even export my files because the buttons get covered because of the resolution (screenshot attached)
I hope someone reads this and help me resolve my problem by looking at these screenshots .
P.S : When I first opened Premier Pro it gave me an error saying it needs a higher resolution(but mine is already at the highest resolution) , had to select dont show again
Correct answer Rameez_Khan
Hi zykhil,
Looks like the scaling is set to 125% at the OS level. Go to Display Properties and change the scaling to 100%
Let us know if this helps.
Rameez
Rameez_Khan
Rameez_KhanCorrect answer
Hi zykhil,
Rameez
PrPro works very nicely within 1980x1020 ... so have you tied to reset all workspaces? An option in the Window/Workspaces menu allows for that. (I'm not at my computer or I'd give a definitive location.)
There's also the User/Documents/Adobe/Premiere Pro/11.0/Profile-User/Layouts folder ... rename that to Layouts Old while PrPro is closed, then restart PrPro and see if that works.
If you can't get a full-window to get your UI into, there's perhaps a problem with the installation of PrPro perhaps. At that point I'd suggest using the Adobe CC Cleaner Tool to both uninstall & cleanup PrPro, then use the CC Desktop app to download/install a fresh copy.
https://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation-problems.html
