Premiere Pro is changing the clip name on import
  • December 3, 2019
  • 5616 views
We are working on PP v14 on OSX 10.15.1
I have footage shot with a C300 mk 2, transferred to our hard drive via Offload. I try to import the footage into our project using the Media Browser. This is the first time I have done this with this updated PP. The file name of the video is something like, "B070C001_1801193R_CANON.MXF"
When I import it into the timeline, Premiere displays it as "CLIPS001". It has the same file name for all the clips I import.
It does this with older footage too that I have imported in past project with this method and, in the past, it has maintained the file name.
Thoughts?
nate
Correct answer mayjain7130546
Hello! I've found the answer to this. Try renaming the folder with those camera files as "CLIP" and it will import normally
Sorry I just discovered this so long after you posted this issue
Hi @azizir94806193  ,
Please check out the latest Premiere Pro version. This should be fixed. There is no need to renaming the folder in the latest version.
Let us know how it goes.
Mayjain
rachelcenter
that is not the answer. its 2022 and i'm having this problem. and its not footage shot from a camera. its footage from a server from a major tv network
quote
By @rachelcenter
It's not the answer, as yours is a total different issue.
Continue here:
https://community.adobe.com/t5/premiere-pro-discussions/premiere-changes-the-clip-name-upon-import/td-p/13251584
seem to remember seeing a post about this problem being specific to the canon c300.  Search the forum and see what you can find.   If I remember from working with material from the c300, I think it creates spanned clips (individual files are automatically created when the file size reaches the maximum allowed in a fat32 formatted card which premiere automatically combines).   Take a look at the file structure of the actual files and see if most of them are about 4 gigs each.
I wondered if it had something to do with the MXF file structure of the C300 mk 2. But the weird thing is that this wasn't a problem with previous versions of Premiere Pro (I've imported footage into an older version of PP without issues within the last month or so). It's only happened with this update. That makes me wonder if there was a setting that I need to update.
I should also note that "CLIPS001" is the name of the folder in which the MXF files live. So perhaps Premiere is naming the files after the folder, not the clip.
This is happening to us on another computer as well.
brianm13736688
This is happening to us as well.
