Premiere Pro is extremely slow
Hi! I don't know if its a bug or not/ problem with the app or problem with my pc. Yesterday premiere pro worked perfectly fine, smooth, no problem with it. Today when i i started to work on my project i noticed it being very very slow. It had moments before where where it would be slow for a few seconds, but thats it, nothing to worry about. But now its different. I can see what im working on (in the preview tab) and then it goes black, the audio still works fine for a few more seconds and then its starting to distort. Also if i press space to stop the clip, it stops after 4-5 seconds. If i close and reopen premiere pro everything is fine for few seconds and then it happens again. I tried to export the project (40 seconds in total and its not complicated, few cuts, few subtitles, usually it took about 3-5 mins to render) and it takes 15-20 mins for it to render.
Is there something i can do ? I haven't made any change in settings.
I dont know if you need it but here are my specs:
Windows 11 Pro
GPU- RTX 4060 TI DUAL 8GB
RAM- 2x 16GB, 3200
SSD- 1TB SSD m2
CPU- AMD Ryzen 7 5700X 3,4GHz
