Sep 26, 2023 3:32 PM UTC
Premiere Pro is playing project in slower speed
I opened my almost finished project and for some reason the playback speed has slowed down. 1 second in the program is not anymore 1 second. This is not a ram or memory related issue. Every project that I open now plays "slower". Speed in every individual clip is set to 100% and the frame rate also matches the same 25 that I used to film. What have I done and how do I fix that my 25 fps project plays 25 frames in 1 second?
Richard M KnightCorrect answer
Sep 26, 2023 4:00 PM UTC
Try setting audio input to none.
Richard M KnightCommunity ExpertCorrect answer
Sep 26, 2023 7:01 PM UTC
That actually worked, thank you! Problem solved.
