Premiere Pro is stuck on import
  • November 7, 2024
  • 1082 views
CC25 version gets stuck on "import Files..."
If I run
app.project.importFiles([file.fsName], true, bin, false);
30 times in a row. It gets stuck once or twice randomly.
When can we expect a fix?
Same code same files work ok in cc24.
Correct answer Bruce Bullis
The bug (which has to do with the progress bar invoked by import) is already fixed in PPro beta builds, and will be fixed in the next official release.
Bruce Bullis
Bruce BullisCorrect answer
Thanks!
