Premiere Pro Issue With Editing Sound inside Audition
If I try and edit a sound file in premiere pro to edit it in audition - Premiere pro seems to not let the audio run.
if I go >> "Edit Clip in Adobe Audition"
So it processes >> "Render and replace"
Then I get a warning >> "Audition has detected a problem with the current audio hardware settings".
(The hardware settings are as they always are I believe).
Currently I have to close down premier pro if I want to use audition to edit the sound file which means I have lost this functionality.
Anyone suggestions?
Thanks ![]()
