Premiere Pro, ITV HD settings, Clearcast and Vidchecker
  • August 7, 2018
  • 5 replies
  • 4988 views
Hi all,
I'm currently preparing some video for ITV HD. I'm running into some issues. Any help greatly appreciated.
This Ad must go through Clearcast and to check the footage they use some standard templates on Vidchecker. It is failing my footage however, my footage passed the DPP template on Vidchecker when i ran the task.
Here are the ITV HD specs
http://dpp-assets.s3.amazonaws.com/wp-content/uploads/specs/itv/HDCommercialsSponsorshipMaterialStandardITV.pdf
I used the AS-11 preset to produce the mxf file and ran it through the DPP template. It passed ok. I sent it to Clearcast and they failed it immediately. Upon further reading i discovered this in their FAQ's
Adobe Media Encoder / Premiere / Episode
We spent a number of hours testing Adobe Media Encoder (AME). We tested Adobe Media Encoder CC 2015.0 release, (build 9.0.0.222). Unfortunately we were unable to convert a progressive source to Interlaced Top-Field first. Some attempts produced a file that reported to be of the correct specification but upon analysis we discovered that the video was still progressive.
We spoke with Adobe Support who confirmed that AME is not able to convert a progressive source to Interlaced Top-Field first. A number of agencies have reported issues with this piece of software. We believe the same is true for Adobe Premiere and also Episode.
We do not recommend the use of this software to produce files for CopyCentral
So with this in mind would i be correct in thinking that because ITV requires Clearcast to clear the video that Adobe Premiere is simply not accepted anymore?
If anyone has an ITV HD preset i could try i would be most grateful. Any advice appreciated.
Best
Chris
    abigailc39326854
    Think I might have solved the issue these. It has been test and works
    Thanks for the comments. I feel much better knowing it's not a unique experience. Although somewhat perplexed as to the mis-information on their website. I am speaking to them today and will let you know the outcome. I did have a friend of mine compress the Quicktime (animation) file with Sorensen Sqeeze using the template they provided. It worked fine for their purposes however it was clearly not broadcast quality. The fact they ask for the final mastered version to avoid any issue with delivery to the broadcaster is somewhat incorrect when their spec does not necessarily meet the requirements of the broadcaster. I will contact ITV directly and give them the MXF for checking. Hopefully they will accommodate me.
    Today i had this response from Clearcast
    "Premier pro doesn't produce interlaced files"
    PrPro does produce interlaced files, which are accepted by most other services.
    I have heard that some utilize other services to avoid Clearcast. As noted above. Their tech answers are simply wrong.
    I have had a phone call from one of the team. He basically said it was their system that needed tweaking to work and of course they recognise Premier pro as one of the industry standards. After i pointed out it was ludicrous to suggest Premiere Pro did not do interlaced. They basically just need to revamp some of their testing. Anyway it's moving forward now.
    If anyone does have a premier pro template for HD TV ads? specifically ITV -  It would be most helpful.
    Thanks again for all the comments.
    I have had exactly the same issue delivering files to Clearcast. Out of my nearly 30 years working in Broadcast TV they remain pretty much the worst company for "The computer says no" failures. The problem is with them and not with how you're making files. Where possible I simply avoid Clearcast and use another company. If you absolutely must use them then I've found producing Prores Quicktimes avoids these failures.
    I deliver maybe a dozen hours of UFF video a day and haven't seen this issue. Mainly using progressive sources and my most common export is XDCAM 422 60i. We also use vidchecker in house for QCing everything and its not failing for wrong field \ progressive when supposed to be UFF. Watching for more info tho
    That was of course what, three major build series ago?
    I would suggest installing MediaInfo on your machine, a free download "we" use heavily around here.
    Drag/drop an exported file onto the app's icon on your desktop, then go into that app's "Tree View" setting, and see what it reports about the video file details. And post a screen-grab by dragging/dropping it into your reply.
    Indeed it was, however this information is still current on their website. This is why i queried it. They have yet to reply.Please see the mediainfo below
    That is showing upper first ... wonder what the deal is? Why does it show upper first if ITV says it isn't? Huh
