Premiere pro Low internal memory crash
  • August 3, 2023
  • 849 views
Hi. When I open my project, Premiere can't show all the clip thumbnails in project panel and I see error messages like: "Frame substitution recursion attempt..." and "a low level expectation accured.." and I have no idea what these mean! I can't play my clips in timeline and after some seconds it crashes and closes the program! I have not changed anything like ram and memory and storage in my computer and looks like I have a new trouble with Premiere again after giving me a break :)) I reset my preferences, uninstalled and installed premiere, moved my project into a new project and changed the locaion, I also tried switching from mercury to software and clear media cache. But none of these worked!!! Please help me with this as I have been working on this project for 3 month and I have a deadline to finish this. Thank you
    Peru Bob
    Try creating a new project and import the old one into it.
    I tried doing what was suggested, but the problem is still there. Basically, as long as I don't open the file in the project panel (where my footage is), everything works fine. But when I open it to check my imported files, Premiere crashs. It's so frustrating!
    Peru Bob
    I tried this and unfortunately didn't work. there were two clips: one is located now and I made the second one offline as I had deleted it before. It's still the same. when I open the folder of footage in the project panel, all those error messages appear and it says " low internal memory ...".
    What are the complete computer specs, including hard drives (how many, what kind, what is on each, what capacity, and how full)?
    kglad
    p.s. i don't think the adobe website, and forums in particular, are easy to navigate, so don't spend a lot of time searching that forum list. do your best and we'll move the post if it helps you get responses.
    <"moved from using the community">
    Thanks for moving the post. I wait for responses.
    kglad
    you're welcome, and yes we'll await premiere pro experts to assess.
