Premiere Pro not opening - need urgent help!
  • June 12, 2023
  • 35 replies
  • 36687 views
As the title says, I cannot open Premiere Pro. It shows the splash screen, but after about six seconds, it disappears and nothing else pops up - not even any crash reports. I have tried practically anything I could think of, and followed steps from the official "How to fix Premiere Pro crash issues". Here are some of the things I've tried...
  • restarting my PC
  • updating my graphics drivers
  • reinstalling the program
  • opening previous versions of Premiere Pro
  • opening via shortcuts, the Creative Cloud, and a project file
  • opening as an administrator, as well as messing with other compatibility settings
  • manually cleaning media cache
...all to no avail.
Below are my specs:
System: Windows 11
Graphics Card: ASUS Radeon RX 6750 XT 12GB
RAM: 32 GB
Processor: AMD Ryzen 5 3600 AM4
For reference, the main version of Premiere I am trying to run is the latest one (23.4)
I would be extremely grateful for any help at all! Thank you! 🙂
Correct answer joed51181206
I had the same problem and it has taken me a month to figure it out.  Tonight I uninstalled my Black Magic apps and now Premiere Pro 2024 loads. I hope that this post helps others with the problem.
premiere pro not openig
Found solution..!!
C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore
you can remove plugins and check it works. if there more than one plugins. you can try one by one. its work. and try newer versions of plugins
Thanks, I had the insta360 plugin and after removing it from the MediaCore folder it worked! thanks a lot
joed51181206
joed51181206Correct answer
Honestly massive thanks. I had tried everything, even got a new graphics card, and it turns out it was just the Blackmagic apps stopping it working.
Huge thanks again.
stu
I am having exact same issues, audo hits a lag and all of a sudden it can't be fixed. if I close it then it woun't open up again. it is stuck on the splash screen. only way it works is restarting my computer after a forced close. I deleted my coomputer last week in frustration with adobe for so long. re intalled everything. it was working good for 1 day and now it's worse than ever with bugs and crashes. I have installed davinci resolve and will start learning it's interface because I can't have my ability to work continuoulsy be cut out from underneath me. which is a shame because I would have liked to use adobes interface on certain things. I've struggled for a year with different problems and bugs. I've done everything everyone says to. if Adobe can fix their bugs to make it work I would love to keep using this product, but it hasn't been a thing concerning my issues.
Did you completely uninstall all traces of the drivers for your previous GPU? If you didn't, then the graphics drivers will conflict with one another.
I may not have, actually. I definitely still have some NVIDIA programs installed despite their uselessness, so there may as well be traces of my previous GPU. Is there any easy way to do so?
The Nvidia Control Panel and all things Nvidia should have been in the "Installed apps" section under Apps in Settings. Please do uninstall all of the apps that say "NVIDIA" by running the Uninstall feature (click on the three dots, then click Uninstall).
Below is a screengrab of the splash screen before it disappears. It looks like this for a couple of seconds, nothing changes on it at all, before disappearing.
I am also both glad and sorry to hear I'm not the only one with similar issues.
creative_03c65777624
We have the same issue with this computer:
Dell XPS 15 9520
Intel Core i7-12700H
NVIDIA Geforce RTX 3050 Ti
32 GB RAM
Windows 11
Windows is up-to-date (it didn't work with the Windows May update, so we tried the June update, but to no effect).
Dell drivers are the latest, too.
Already tried installing NVIDIA Studio AND Gaming drivers.
Disabled third-party-plugins, reset preferences via Adobe Creative Cloud Diagnostics (Beta) tool.
Adobe Premiere CC Version is 23.4, but we also tried installing 23.3.
The only software that was installed between the time it worked and now was Camtasia 2022.
After uninstalling Camtasia version 22.4.1.42246 Premiere can be started again.
I have the exact same problem. It worked fine until today, I updated windows yesterday, maybe it has something to do with that. And my laptop also has similar specs to yours.
Ishan Y
I'm sorry to hear about this. Could you share more details? Is Premiere Pro stuck on the splash screen, or are you unable to see the splash screen as well?
Yes, the splash screen is visible for a few seconds before disappearing. It does not say it is loading anything, either.
Ishan Y
Hey WaterSpace,
I'm sorry to hear you're experiencing this issue. I have moved your post to the Discussions section for troubleshooting. Please launch Premiere Pro with the Alt key pressed and select the Disable Third-party plugins (one-time only) option. Let us know if you still see the issue.
Ishan
Good afternoon!
I have tried opening the app with the ALT key, and the same thing happens. It is not showing up with any options, it just does the same thing.
I tried opening a different app like Photoshop with the ALT key but it just opened normally without any prompts popping up.
Ishan Y
You can try holding Ctrl, Shift, or Alt to enable the Reset Options menu. Please check out this video and try again: https://www.youtube.com/watch?v=jdpG79no3oQ&t=2s
Just an update that I am still unable to open the program. Any help?
