Premiere Pro Not Responding Problem
My computer can run every adobe product except Premiere Pro.
When I run the software, it says not responding.
I downloaded Premiere Pro on this computer before. But I deleted it some weeks ago. I re-downloaded today and it gives this problem.
I also tried to download older versions but they also don't work.
I tried to end task from task manager. It does not fix the problem.
If you have any suggestions, please share with me! Thank you!
Also, I found this help message from 2019:
0. Double check you have the latest Premiere and graphics versions installed
1. While launching Premiere, hold down Shift + Alt (Windows) or Shift + Option (Mac). This resets your preferences.
2. Delete your media cache files - https://forums.adobe.com/thread/2152942
3. Try moving your Media Cache to a new location
4. Uninstall Premiere Pro > Run cleaner tool (https://helpx.adobe.com/creative-cloud/kb/cc-cleaner-tool-installation-problems.html) > Reinstall Premiere Pro
I tried the first 3, they did not work. 4th, I could not manage to do.
My computer is Windows 10. But every other Adobe product I use are the latest version.
My computer is dell inspiron 15 7577.
Waiting for the help! I need to use it for a project. Thanks!
now I also tried to 4th option but it did not work again.
You have done all the obvious.
Might want to contact support.
