Premiere Pro not using Dedicated GPU.
  • January 24, 2023
  • 14 replies
  • 494 views
Premiere Pro is not using my Dedicated Graphics card: GTX 1080 6GB. It is using the CPU and my internal GPU, even if I set all the settings to use the GTX and add the card to cuda_supported_cards.txt.
same issue here with my helios 300 gtx1060... tried using 2018 and 2019. I can disable the integrated gpu but then i can't do hardware encoding, only software... so still can't use my 1060 properly for editing as i want
Premiere 2019 not using my 1050Ti MaxQ
Worst on Premiere Pro 2019 !!!
Slanny
Same for me with the GTX 1070...
