Premiere Pro not using Nvidia GPU for rendering
  • January 24, 2023
  • 37 replies
  • 5932 views
My laptop has an Intel integrated GPU and a Nvidia Gtx960M GPU, however premiere pro will only use the Intel GPU for rendering, even if I have set the renderer to be CUDA and forced premiere to use the Nvidia GPU in Nvidia settings.
6820HK 970m Premiere uses internal GPU and not the Nvidia.
8700K 1070ti same problem.
MS Surface Book 2, Nvidia GTX 1060, Intel UHD 620.
Ignored: Nvidia GTX 1060
Pinned: Intel UHD 620
FIX IT!
Having the same issue.
I'm having the same problem with my Nvidia 960, premiere seems super slow since 2018 update. And seems to only be using integrated graphics. Please fix this, Adobe! Thanks!
For those who live on the Mac side of life:
Use this free tool to switch GPUs! I use this since years and it's great! 🙂
https://gfx.io/
I have this issue. I've tried the proposed solutions from the Adobe Forums but they didn't work. I have a laptop with integrated Intel HD Graphics 630 and Nvidia GeForce GTX 1050 Ti. Premiere is using the integrated GPU.
I am having this issue as well. I've tried many combinations of settings as described in this thread but can only ever get either the CPU or the Internal GPU to render while my NVIDIA GeForce GTX 1070 Ti sits idle. It's like having a sports car in the garage but being forced to ride a bike instead. Please help!
