Premiere Pro on MacBook Pro M2 Max looses connection with multimedia files-needs forced exit
  • April 9, 2023
  • 1527 views
Last night I rendered/exported my last project without problem. This morning I opened the project to find that it no longer connects to the original files. When I try to “find” one file, the program goes on block and I have to force the exit. I have found the same problem when trying to load previously developed projects.
I hane disinstalled Premier Pro and installed it back. I have restarted the Mac.
To no avail
Premiere Pro latest version on MacBook Pro M2 Max - MacOs Ventura 13.2.1
Correct answer recorpac
Yes, I've seen that issue a couple times in the wild these days. More than usual. Anyway, glad you got going again.
Cheers,
Sorry to cotraddict you, Kevin, but tha right answer i where I write “I have reversed the Insta360 Studio version to 4.6.6 as instructed here: https://www.reddit.com/r/Insta360/comments/yxdpw1/insta360_57k_premiere_pro_error_a_lowlevel/”.
I had messed up my timeline later...
Cheerio
Renato
Peru Bob
Delete the Media Cache and Media Cache files:
https://community.adobe.com/t5/premiere-pro/faq-how-to-clear-your-media-cache-in-30-seconds-in-premiere-pro-2020/m-p/11017257/thread-id/260446?page=1
If that doesn't work, try resetting the preferences:
https://community.adobe.com/t5/premiere-pro/faq-how-to-reset-trash-preferences-in-premiere-pro/td-p/8236158?page=1
Reset a workspace
1. Do one of the following:
• Click the Workspace menu icon and select Reset to Saved Layout.
• Choose Window > Workspace > Reset to Saved Layout.
from here:
If that doesn't work, try Preferences > Audio Hardware and set Input to None.
If that doesn't work, try creating a new project and import the old one into it.
recorpacAuthor
Thank you Bob. I'm in the Rome time zone, so I just woke up. I was about to reinstal MacOs, but I'll try what you suggest first. I'll let you know.
Peru Bob
Are the files located on an external drive?
recorpacAuthor
Yes...
recorpacAuthor
Thank you for answering. Yes, all files are located on an external drive. Is it relevant to the issue?
recorpacAuthor
All this has happened on Premiere Pro version 23.2
I have since didinstalled 23.2 and installed back 23.1.
To no avail
