Premiere Pro performance issue with 17 stacked ProRes Proxy layers in UHD sequence, looking for best workflow
I’m looking for some workflow advice from editors cutting heavier performance-based material in Premiere.
I recently finished a band performance shoot where I have 17 takes of the same song stacked in a single sequence, essentially 17 video layers one above the other. My goal is to cut it almost like slicing a layer cake from top to bottom, meaning I want to move through the stacked takes visually and choose moments from each layer as I build the final edit.
I haven’t cut a music video in years and this way of cutting was never an issue but I also never cut open gate material inside of a UHD timeline.
Here’s the issue:
Even when only the top visible layer is actually showing in the timeline output, I’m still getting dropped frames and laggy playback. It feels like Premiere is still trying to evaluate or play all 17 layers at once, even though nothing underneath the top layer is visible unless I cut down to it.
My setup is not weak:
Mac Pro M2 Ultra. 192 GB RAM. Mac OS Sequoia latest update.
Media stored on a very fast OWC internal SSD. 12,000mbps read and write speeds.
Camera originals were ARRIRAW open gate plus some Phantom 4K Flex material
I transcoded the ARRIRAW footage to ProRes Proxy
Proxies were made at the original source resolution
I’m editing in a UHD timeline (3840x2160)
Since the source was open gate from Arri Alexa 35, every clip is being scaled/reframed into the UHD canvas
So I’m wondering if the problem is less about drive speed or codec, and more about the fact that Premiere is still processing all stacked layers, all with scaling, even when only the top layer is visible.
What I’m hoping to find out:
Is there a better way to make Premiere effectively ignore the layers underneath unless they are actually exposed?
Is there a workflow for this kind of stacked performance edit that is better than manually piling up 17 takes in one sequence?
Would I have been better off making the proxies at a lower raster instead of original source resolution?
Is there some Premiere setting, workflow trick, or sequence strategy that helps when cutting lots of stacked takes like this?
Again, the idea is to cut by revealing the next layer down, almost like peeling or slicing through stacked performances, not necessarily using a traditional multicam approach unless that is truly the better route.
Would love to hear if anyone has dealt with this exact kind of edit and found a smoother method.
Thanks in advance.
