Premiere Pro problema con l'audio durante l'editing
  • June 25, 2023
  • 573 views
Durante il lavoro di editing video, vado in riproduzoopne per verificare il risulto, ma capita di sovente che mi salta l'audio non sentendo più nulla, mentre il video continua la sua riproduzione.
Premetto che sto lavorando con un'impostazione del proxy, pur avendo una configurazione nelle preferenze con una ram base di 64 GB di cui 52 GB riservate per Premier Pro. QUesto permette alla riproduzione video di essere fluida. Ma il problema con l'audio non riesco a risolverlo.
Mi sapete dare consigli in merito?
Kevin-Monahan
Hi @GiuGar,
Can you try a test without the mp3s? Those are very compressed and don't work well with video editing.
GiuGarAuthor
Thanks for your help Kevin.
It is a test that I had already done, muting the audio track where I have the backing track which is in MP3, but the voiceover track which is in wav skips anyway. I haven't tried the reverse: i.e. Mute the voiceover track and listen to the background music if it has the same fault.
I will try again in the evening and let you know.
Kevin-Monahan
Cool. Yes, please report back when you can.
Cheers,
Kartika Rawat
Hi there!
Sorry about the issue. Can you share the following information?
  • What's the source of the media files?
  • Could try changing the Default input to No input and see if that brings any change? Edit > Preferences > Audio Hardware
Let us know.
Kartika
GiuGarAuthor
It is improved by setting "No Input". Even though the audio skips less
frequently now, it still happens.
The audio format I use is wav and MP3
_______________________
*Garzia Giuseppe & Family*
[Personal info deleted by mod]
