Premiere Pro Program Monitor Problem after link with an After Effect Composition
I sending videos premiere pro to after effects for some effects but when i'm done with after effect i saving composition and when i opened premiere pro back screen of my video splitting weirdly at program monitor and Project menu. I couldn't find any solution.
Thomas30730035c384Correct answer
I solved this issue. When i am facing with issue i was using After Effects 2022. After that i updated After Effects 2022 to 2023 and problem solved.
Thanks for reporting back @Thomas30730035c384!
Hello @Thomas30730035c384 & @Intimation_three,
Thanks for the messages. Please make sure that the versions you are using for Premiere Pro and After Effects have been updated to the most recent ones. That has fixed the issue for others.
I'm having the same issue.
Thomas30730035c384AuthorCorrect answer
Known issue: revert to previous version.
Is this problem belongs to Premiere Pro or belongs to After Effect?
Dynamic link.
