Premiere Pro Rendering and Exporting Problems with Intel Iris Xe Graphics
  • November 17, 2022
  • 2594 views
I have a new Hp Envy laptop with:
12 gen Intel core i7-1260p
16gb ram
Intel(R) Iris(R) Xe Graphics
Whenever I tried to export or render my projects it will get stuck loading in the rendering loading screen and freeze at different but low percentages and force me to close the app as it will freeze. Whenever I look in the task manager the GPU will sometimes spike up and come down once or just stay active at a low percentage. But I have found when I turn on encoding to software from hardware rendering and exporting will work fine. From what I have found my gpu should be strong enough to work on 1080p video with it's 7.9gb memory and for it being from a new higher end laptop. Is there any fix to this problem? Is this a bug with the newest premiere? Or am I out of luck?
Correct answer Micah27193146rmqe
Update after I have Updated using the intel and hp driver updates I can now use my GPU to export. Thanks for getting me to take a second look at the drivers the first time I checked was just in the device manager and checking for driver updates that way. Still a bit annoyed that the OEM drivers for a computer from this year or last year do not work very well... Hopfully I do not run into any problems now. Thanks again!
Peru Bob
Have you tried updating the graphics driver?
Micah27193146rmqeAuthorCorrect answer
The driver that I downloaded was "Intel Arc Graphics Windows DCH Driver" for anyone else who ever has this same problem later.
