colind26465616
Premiere Pro Slow with Red Giant Universe and Audio Clips Going Mute
  • November 12, 2018
  • 4620 views
Hey guys!  Im very new to Premiere Pro.  So, please forgive any naivete on my part.  But, I'm experiencing the following:
- Extremely slow render times, playback and general program slowness any time I employ Red Giant Universe Plugins
- Also slowness (near crashing) when I use "transform"
- Upon closing and reopening Timeline I'm finding audio attached to Red video files going suddenly blank.  Clips are in place, but dead.
I am working with Red 4k and 5k footage, as well as Sony as7ii 4k footage.  Project sequences in 1080.
Any tips on improving this speed?
System:
GeForce GTX 1080 Ti (Driver 416.81)
Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz 2.10 GHz (2 Processors)
63.88 GB RAM
64-bit operating system, x64-based processor
Thank you!
Just wondering if anyone ever figured this out? Having similar problems with Red Giant Universe where it slows down the program to an unbelievable degree. Happens in 2017/8/9 and specs of the computer are fairly similar. Have already done a clean Windows install asnd removed and reinstalled all Adobe apps, as well as reinstalling Universe itself.
What's the ghz of the CPU/s? Pr tends to prefer faster cores over excess cores ... and the OP's machine while loaded with cores is at only 2.1Ghz.
It's an Intel 5960x @ 3Ghz, 64GB RAM, Titan X. Shouldn't be causing this much trouble on a system of this capabilities.
colind26465616
This also just happened:
That's giving you a timecode for where it fritzed. Go there on your sequence and see what's going on. You may need to remove the clip then replace it from the bin, redo effects, or maybe dump the cache.
